csouthwell
Jul 29, 2020Follower
RBS20 out of stock everywhere
Why is it the RBS20 is oout of stock everywhere? Is this item discontinued?
Jul 29, 2020Guru - Experienced User
You can try getting ahold of a EX7500 or EX7700 which would work as a RBS.
csouthwell wrote:Why is it the RBS20 is oout of stock everywhere? Is this item discontinued?
- ShinedownAug 24, 2020Apprentice
Also finding this, RBS50 also out of stock everywhere in the UK.
- MstrbigAug 24, 2020Master
Right now the Orbi RBS40V is on sale for $99 on Netgear and if you give them your email address you will get 10% off your first purchase. Great coverage and Harmon Kardon speaker system with Alexa. Good price compared to purchasing an RBS22 and more powerful.
- ShinedownSep 16, 2020Apprentice
FYI, I contacted Netgear in relation to this - they told me they had been impacted by supply issues, but stock will be hitting the shelves in the UK at the end of September. Nothing is discontinued.
