wisesam
Dec 03, 2021Aspirant
RBS20 Poor Backhaul Status
Hi Everyone. Just wondering if anyone experienced a sudden poor backhaul/disconnects? My orbi runs fine where they were in the last 1.5 years. Now it's been a week where the satellite just won't ...
Dec 03, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- wisesamDec 03, 2021Aspirant
Not sure it is fibre broadband modem to ethernetWhat is the size of your home? Sq Ft?
around 180m2
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.building made by bricks
distance about 15m away (in the last 1.5 years)
distance now 1m away (with poor backhaul status)
yep 4 detected from PC
Yep
Seemed like the satellite is faulty
