Jimmychan1007
Mar 01, 2023Aspirant
RBS20 Power Indicator in Red
Hi All My Satellite RBS20 power indicator suddenly turns Red and can not connect to the router anymore. How can i fix it? Tried to reset the satellite number if times but it does not work at all. Pl...
Mar 01, 2023Guru - Experienced User
Red powerlight tends to indicated a corrupt firmware.
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
