Spanky_Partain
Jan 30, 2020Aspirant
RBS20 Remole Reboot
How can I reboot the RBS20 remotely? Why can't I go directly to the RBS20 in a browser and there is NOT a selectable function to reoot the satellite? What does this all mean? I do not see this ...
Jan 30, 2020Guru - Experienced User
RBSs have never been supporting of remote access or reboots. Users have asked about this. Only NG engineering and design know this.
So in this case, I placed a networkable managed power strip that has a web page that has remote power OFF functions that I can use to power OFF my RBS then back on.
- CrimpOnJan 30, 2020Guru - Experienced User
FURRYe38 wrote:So in this case, I placed a networkable managed power strip that has a web page that has remote power OFF functions that I can use to power OFF my RBS then back on.
Cleaver idea. I would have expected that the power strip would be connected to the satellite, so when it killed power, the loss of power would in turn kill the power strip. Can you please explain more about "how this works"?
- FURRYe38Jan 30, 2020Guru - Experienced User
Well your close. No this is a managed network power strip which has it's own power connection to the wall out let. The strip is LAN connected to your network. The strip has it's own web page with power ON and OFF settings and features. The RBS's power adapter is plugged in to this managed power strip. Selecting the power port in the strips web page will turn OFF or back ON the port where the power adapter is plugged into the strip. Some have two power ports, some have more:
FURRYe38 wrote:No this is a managed network power strip which has it's own power connection to the wall out let. The strip is LAN connected to your network.
Thanks for the link. Cool. Sorry I was not precise. This works because the switch has an ethernet connection back to the router?
(not a WiFi connection to the Orbi satellite. By "kill" I meant that with the Orbi WiFi down, the switch web page would be inaccessible. It is SO frustrating not having ethernet cables strung throughout the house.)
