Spanky_Partain
Jan 30, 2020Aspirant
RBS20 Remole Reboot
How can I reboot the RBS20 remotely? Why can't I go directly to the RBS20 in a browser and there is NOT a selectable function to reoot the satellite? What does this all mean? I do not see this ...
Spanky_Partain
I have a garage about 50' from my house and I have a Cat6 Cable from the rbs50 connected to my rbr50. Remotely is loging into the rbs50 via IP through a browser. Telnet does not work at all. Seems the rbs50 will not accept a telnet session through the PowerShell on Win10.
Seems there would be a simple way for being the manager to easily do this without issue.
CrimpOn
Jan 30, 2020Guru - Experienced User
Thanks for clarifying the need. This is much more "doable" than "remote from outside the LAN."
Perhaps the instructions were not clear.
- Learn the IP address of the Orbi satellite (from the Attached Devices page)
- Open a web browser to the satellite debug page with http://<ip of satellite>/debug.htm
- On the debug web page, check the box labeled "Enable Telnet"
- Open the command environment. (I use a "CMD: Box", but PowerShell should be about the same.)
- Start telnet. I type
telnet <ip of satellite>, such as telnet 192.168.1.2 - The login prompt will come up. Enter the login credentials: "admin" and the administrative password.
- A linux prompt will come up, something like RBS50#
- At this point, type in the command
reboot
Is this exactly the procedure you followed?
I dare not test this until the family leaves the house. FURRYe38 reported that it did not work for him.
