timtunesguru
Mar 17, 2025Aspirant
RBS20 Satellite Red Flashing death light
NETGEAR RBK23-100UKS (purchased 2019) Hello, my RBS 20 satellite is out of sync with the other satellite and router but I can't access it as the power LED just flashes I have downloaded the r...
timtunesguru
Mar 18, 2025Aspirant
Thanks Kevin
I can't access the satellite via ethernet - neither Windows or Mac will see it - I guess because of the red slashing power light.
Reset won't work either..:(
Mar 18, 2025Guru - Experienced User
Can try a 30-30-30 reset on it and see. If this fails, most likely the RBS needs to be replaced.
