JWhite04
Jan 27, 2021Aspirant
RBS20 Satellite Showing Poor Connection Since Netgear Armor Activated
Recently I've noticed poor performance from our RBS20 Satellite. This is not something I've experienced in the year and a half of owning the system. I've tried to remove and re-add the Satellite - ...
JWhite04
Jan 29, 2021Aspirant
Thank you for the response. Apologies for the brevity of the first message, but I was typing on my phone and we all know how much fun that is.
I would estimate the distance is approximately 45ft to 50ft from Router to Satellite.
I did not unplug the entire system after disabling the Netgear Armor. I'll do that after we wrap up work today. I had only performed a restart of the system in the app.
Some additional details you may find useful.
We have AT&T Fiber (300Mbps) internet and their standard BGW210-700 modem which has not had any issues to date.
The construction of the home is long and narrow single story and provides a fairly open pathway from Router (at one end of the house) to Satellite (at the opposite end of the home.) The plan is to install a 2nd satellite in a separate studio we have at the far end of the house another 50ish feet from the 1st satellite.
I hope this helps provide additional color regarding the issue.
Jan 29, 2021Guru - Experienced User
Your ISP modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
In regards to Armor, seen it where even after disabling Armor, can still cause problems so a reset and setup from scratch with out Armor maybe needed...
- JWhite04Jan 29, 2021Aspirant
Sorry, I should have been more clear. The Orbi routed is connected to the AT&T modem and we are not using Wi-Fi from the AT&T modem. Wi-Fi is not disabled and hasn't been since the Orbi was installed in September 2019. It should be noted that there were no issues with connectivity to the satellite until 2020.
Performing a factory reset of the Orbi system is not desireable given the number of components connected, but I may try it. I would prefer Netgear to have offered a product that works and didn't degrade performance of the components.
- FURRYe38Jan 29, 2021Guru - Experienced User
Armor can be problematic and cause odd issues. Why I don't use it. My Orbi AC works fine with out it.
There is a Armor forum specifically meant for help and information for users that use Armor:https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.- JWhite04Jan 29, 2021AspirantHello, so I can perform a factory reset, but Armor is tied to my Netgear account so won't it just be recognized when everything is setup again or would I met to create a new Netgear ID?
