renanmarques
Mar 08, 2021Tutor
RBS20 Satellite slow internet speeds, both on Wifi and Ethernet connected devices
Hello, after reading through (and testing) pretty much everything there is about this very common issue in all forums/comunities available out there, I have not been able to solve the problem. He...
DrKevorkian94
Mar 19, 2021Tutor
Having the exact same issue, tried everything as you did. I even bought a new satelite to see if it was the hardware, and that did not work either.
- FURRYe38Mar 19, 2021Guru - Experienced User
Does your problem relate to this?
If so, please reach out to the forum moderator.
DrKevorkian94 wrote:Having the exact same issue, tried everything as you did. I even bought a new satelite to see if it was the hardware, and that did not work either.
