TechGeezer's avatar
TechGeezer
RBS20 Satellite units not detected with wired backhaul
I have RBR40 + 3 RBS20 running firmware V2.3.1.44 and ethernet wired backhaul. The RBR40 is configured as AP not router.  When I login to the RBR40 and check the devices no Satellite units are detected, however they are listed as wired connected devices. Is this normal?
  • FURRYe38's avatar
    What is the Mfr and model# of the ethernet switch if one is in the configuration.
    Is Daisy Chain enabled or disabled? Should be disabled.
  • FURRYe38's avatar
    Any progress on this?
