dtoub
Apr 22, 2025Aspirant
RBS20 satellite won't connect
I have a satellite that is now offline. I've reset it etc and no luck. The firmware is older than the other satellites and router, so I downloaded it but the disk image keeps saying it's corrupted wh...
- Apr 22, 2025
Do not open the actual FW file on the PC. Just use it and a web browser connected to the RBS web page and there is a FW update feature there where you select the FW file for the browser to then send it to the RBS thru it's web page.
Does the RBS connect to the RBR if you ethernet connect it to the back of the RBR LAN port?
dtoub
Apr 23, 2025Aspirant
As mentioned, it came back online but I updated the firmware just the same (over a WiFi connection even though I do have ethernet hooked into my MacBook Air normally). All good.
Apr 23, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
