fmalloy
May 27, 2020Luminary
RBS20 Satellites - momentary magenta
Brand new RBR20 with 2 RBS20 satellites. Installed yesterday, worked fine. Both satellites have Good backhaul status. Things looked stable so this afternoon updated firmware to V2.5.1.16 using manual...
fmalloy
May 29, 2020Luminary
FURRYe38 wrote:Has a factory reset and setup from scratch been performed since last FW update?
To try to answer the questions (admittedly they are generic):
About factory reset - wouldn't that put the firmware back to the shipped version, undoing the latest firmware install?
I have no idea what the make/model of the modem is. It resides in the attic connected to the dish antenna on my roof. It has been very solid. Would the modem impact router-to-satellite communication?
House is 2400 sq. ft. Distance is about 30 ft between the router and sats. It's a triangle pattern.I get a blue light when i connect the sats.
I am using Auto channel and default 5GHz. Would that impact communcation to the sats?
Yes, I have multiple neighbors nearby. I can see sometimes >10 other Wi-Fi APs from my neighbors.
I had Fast Roaming on but turned it off. Still lost connection. Would the others really matter for a router-to-satellite connection drop?
It is very solid, but the connection infrequently and randomly drops momentarily, then reconnects.
Jun 01, 2020Guru - Experienced User
fmalloy wrote:To try to answer the questions (admittedly they are generic):
NO!
House is 2400 sq. ft. Distance is about 30 ft between the router and sats. It's a triangle pattern.I get a blue light when i connect the sats. RBS top ring LED should turn fully OFF after a short period of time being on BLUE.
Can you see what channels they are using? This maybe a factor why you maybe seeing odd issues with RBS.
I had Fast Roaming on but turned it off. Still lost connection. Would the others really matter for a router-to-satellite connection drop? To test this, disconnect the LAN cable from the RBRs WAN port. Then look at the RBS. RBS I believe should not show PINK.
- fmalloyJun 01, 2020Luminary
When the RBS spontaneously reboots, it turns white, then pulses white for a while, then goes out when it's done rebooting. It doesn't turn blue, the satellites do that.
Unfortunately i cannot. With my R7000, I changed the channels to avoid interference. When I had interference, I would have Wi-Fi issues but it would not reboot. I will try to play with the channels.
Not sure I understand this - when I disconnect the cable from the WAN port, it turns pink because there is no internet connection; I think it's supposed to do that, right?
I have to believe I have a bad unit. Sometimes it reboots after 24 hours, sometimes after a few hours. It's random.
- FURRYe38Jun 01, 2020Guru - Experienced User
Do the RBS turn PINK when you disconnected the WAN cable? Just checking this. They shouldn't.
Something to contact NG support about and see about additional help and information.
IF you've updated FW, factory reset everything and you still see this issue, i'd check with NG support.
- FURRYe38Jul 24, 2020Guru - Experienced User
Any progress on this?
fmalloy wrote:> RBS top ring LED should turn fully OFF after a short period of time being on BLUE.
