TroyKehoe
Mar 02, 2020Aspirant
RBS20 Setup for HomePod Smart Home (Lutron Lights, Smart Locks, etc.)
Greetings, I hope someone can help.... I am trying to make my home smarter and it is making me dumber. So the thought is, hook the Orbi RBR20 plus a satellite up to the Arris DG1670A Router and ess...
- Mar 02, 2020
Is the Orbi system operating in Router or AP mode?
If your ISP modem already has a built in router, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI recommend trying option #3. The articles will help you get the Orbi setup for AP mode.
You can use the same SSID name and PW as you had used on the modem/router if you want to use this. Helps in devices connecting and migrating to Orbi.
Mar 02, 2020Guru - Experienced User
Couple of options,
- TroyKehoeMar 02, 2020Aspirant
Thank you! Thank you! I used option 3 and it seems to be working. FYI, before getting your response, I switched to AP Mode and it took awhile, but internet finally got restored and everything was working OK. But, I did not disable the wifi radios (the router had a 2.4 GHz and a 5GHz radio.) Once I got your reply, I found out how to disable the wifi radios and did that. The only thing I did not do is change the SSID and PW back to the original. It still has the same name I gave it when originally setting up the Orbi. You mentioned it helps migrate items to Orbi, do you think I should change the name back?
Thanks again! It is great to see the community helping each other.
- FURRYe38Mar 02, 2020Guru - Experienced User
If you change the SSID name, then you'll have to ensure your devices connect to the new SSID name.
Glad it's working.
Enjoy. :smileywink:
