SteveBBQ
Apr 25, 2022Tutor
RBS20 won't reset
Hi - I just updating to the new firmware available for my Orbi system, and for some reason one of my two satellites got messed up. I have tried the 30-30-30 and the regular reset, and I can't get eit...
Apr 25, 2022Guru - Experienced User
"messed up"
whats actually going on with the led and the satellite?
have you tried hardwiring them into the router and syncing them?
SteveBBQ
Apr 25, 2022Tutor
From what I can see it looks like it keeps boot cycling? I haven't been able to get any devices connected to it.
Satellite from cold boot:
- Blinking white halo, green power LED
- 30 seconds later, pulsing white halo
- 3 minutes later, solid blue halo, but orange icon in app
- halo goes off, but still orange icon in app
- Pulsing white halo, orange icon in app
- Solid blue halo, orange icon in app
- Light off, green icon in app
- Blue light back on
- White flashing halo back on
- White pulse back on
- Light off
- SteveBBQApr 25, 2022TutorJust attempted to hardwire satellite into router and it appears to be doing the same boot loop.
- plemansApr 26, 2022Guru - Experienced User
You tried a factory reset?
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash- SteveBBQApr 26, 2022TutorI have tried holding down the reset pin until the power light flashes amber several times.
I’m on MacOS; is there a guide for using that?
