SteveBBQ
Apr 25, 2022Tutor
RBS20 won't reset
Hi - I just updating to the new firmware available for my Orbi system, and for some reason one of my two satellites got messed up. I have tried the 30-30-30 and the regular reset, and I can't get eit...
Apr 26, 2022Guru - Experienced User
You tried a factory reset?
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
SteveBBQ
Apr 26, 2022Tutor
I have tried holding down the reset pin until the power light flashes amber several times.
I’m on MacOS; is there a guide for using that?
- plemansApr 26, 2022Guru - Experienced User
here's a guide someone made for the r7000. should be pretty similar.
- SteveBBQApr 26, 2022TutorI got all the way through that, but I didn’t have success attempting to upload the firmware. I kept getting a message that the upload had timed out.
It can take a few attempts as its sensitive to timings. I've tried up to 6 times before it finally worked. nmrpflash isn't as sensitive but not sure about its working on a mac
