SteveBBQ
Apr 25, 2022Tutor
RBS20 won't reset
Hi - I just updating to the new firmware available for my Orbi system, and for some reason one of my two satellites got messed up. I have tried the 30-30-30 and the regular reset, and I can't get eit...
SteveBBQ
Apr 26, 2022Tutor
I have tried holding down the reset pin until the power light flashes amber several times.
I’m on MacOS; is there a guide for using that?
Apr 26, 2022Guru - Experienced User
here's a guide someone made for the r7000. should be pretty similar.
- SteveBBQApr 26, 2022TutorI got all the way through that, but I didn’t have success attempting to upload the firmware. I kept getting a message that the upload had timed out.
- plemansApr 26, 2022Guru - Experienced User
It can take a few attempts as its sensitive to timings. I've tried up to 6 times before it finally worked. nmrpflash isn't as sensitive but not sure about its working on a mac
Got it - thanks for the background. I will keep working on it and see if I can hit the sweet spot for timing so it starts working.
Would it make sense to attempt to reset the entire system and reload the backed up config file as a bypass for this process?
