SteveBBQ
Apr 25, 2022Tutor
RBS20 won't reset
Hi - I just updating to the new firmware available for my Orbi system, and for some reason one of my two satellites got messed up. I have tried the 30-30-30 and the regular reset, and I can't get eit...
Apr 27, 2022Guru - Experienced User
You could try resetting but I wouldn't reload a backup config. if the configuration is the issue, reloading it just re-causes it.
SteveBBQ
Apr 29, 2022Tutor
Thank you for the help - I was able to reload the firmware and it’s exhibiting the same behavior, so I think it’s just bricked at this point.
I’m not sure what else there is to do?
