beddingfield
Apr 27, 2021Follower
RBS20
i have the RBS20, and would like to have the best information to extend the range to my shop which is 250 away from the main unit.
Apr 28, 2021Guru - Experienced User
250ft is to far away to reach.
You'd either want to run an ethernet wire or use a point to point system.
Netgear makes Airbridge which is a point to point system or there are cheaper models you can get.
