defjab2
Sep 21, 2023Follower
RBS20/RBR20 Firmware
I haven't seen an update since December - is netgear no longer addressing active threats as I see other models getting fairly frequent (security) updates ? I did confirm that products are NOT EOL
Sep 25, 2023Guru - Experienced User
And?
Are you having problems with your system?
Usually if there are not issues at hand, NG doesn't release any FW updates.
Also may take months and months for new FW to appear. Especially as the model series ages, FW updates don't releases as frequently.
