JJDaner
Jun 19, 2020Follower
RBS40 Blocking Internet
My Orbi Wifi is again blocking Webpages I regularly use. I called support before and they had me change an IP and the issue was resolved. Now, after an update, the issue is back and Orbi support will not help anymore.
Does anyone know what to change in Settings so I can use the friendly Internet again?
1 Reply
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerHas a factory reset and setup from scratch been performed since last FW update?
