emitter
Oct 06, 2018Initiate
RBS40 firmware V2.2.1.210 failed -- what next?
Early this year I added an Orbi Mini RBS40 satellite to my existing RBR50 + RBS50 network. I was recently logged into .1.1 as admin and noticed that a firmware upgrade was available. I clicked t...
- Oct 07, 2018
The RBS40 should have been updated before you updated to v210?
THe RBS needs to be update then it should reconnect. Try installing a middle of the road version on the RBS, try v2.1.1.12. If you can get this installed, then try v210 on the RBS. I ran in to this same situation that you can't go from OLD FW to New FW. Theres a middle of the road FW that has to be installed first.
Oct 07, 2018Guru - Experienced User
