carterryan22
May 30, 2020Aspirant
RBS40 LED ring flashing white, not able to factory reset
Hi all. Came back from a trip and noticed our RBS40 LED ring was flashing white. Confirmed it was marked as disconnected in the app. Tried a power cycle without success. Used a pin to do the factory ...
May 30, 2020Guru - Experienced User
Power off the modem for 1 minute then back on...
- carterryan22May 30, 2020AspirantThanks for the reply.
Not sure how modem is relevant to the issue. Internet connectivity isn’t the problem. But it’s a NVG468.
Firmware is 2.5.1.16
