carterryan22
May 30, 2020Aspirant
RBS40 LED ring flashing white, not able to factory reset
Hi all. Came back from a trip and noticed our RBS40 LED ring was flashing white. Confirmed it was marked as disconnected in the app. Tried a power cycle without success. Used a pin to do the factory ...
Jun 01, 2020Guru - Experienced User
Press the back reset button for 15 seconds then release. Disconnect the RBR from the modem and just connect 1 wired PC to the RBR.
Can you access the RBRs web page at 192.168.1.1 after the top ring LED slowly pulsates WHITE?
