snoopy1212
Mar 24, 2020Aspirant
RBS40 not syncing on ethernet backhaul
Hello all, I am running 1 x RBR40 w/ 2 x RBS40 in AP mode. Both satelites connected using ethernet backhaul. One of the satelites works fine everytime and gets the blue ring on top. However, ...
CrimpOn
Mar 24, 2020Guru - Experienced User
One test is to eliminate the ethernet cable as a problem. i.e. bring the satellite to the same room as the router and connect them with an ethernet patch cord.
