numzie77
Apr 05, 2020Guide
RBS40 satellite - will this power plug work
Hi I accidently broke one of the legs on the EU power plug for my Satellite - so now I'm looking for a replacement (the one I had was also a replacement as I bought the Orbi set second hand). It ...
Apr 05, 2020Guru - Experienced User
You might contact the seller of the adapter to see if it will work for your RBS. I believe it should.
Just make sure the voltage and amps match the original power adapter values.
- numzie77Apr 05, 2020Guide
Seller does not know. But here is the adaptor I use today (attached).
Here is my current adapter on a photo link:
