boobie_doobie
Sep 09, 2020Initiate
RBS40 Satellite with CBK40 system?
Posted this in main forum, but was suggested to post here as well. Any thoughts would be appreciated. I have a an RBK40 mesh system (router + 1 satellite) currently, but need to upgrade my arris su...
Sep 09, 2020Guru - Experienced User
Most isp's don't support the CBR40 for gigabit speeds. Most of them require a docsis 3.1 device for gigabit speeds. I'd check that first if you're wanting gigabit now or at some point.
I'd go with either the CM1000, CM1100, CM2000. I'd avoid the cm1200 unless that's all you can get. Reason why is many mistake the 4x ethernet ports on it for "usable" ports where only 1 device can connect to the cm1200 for most isp's. (a couple isps you can use all the ports but its rare)
boobie_doobie
Very helpful plemans, thanks for the advice, think I will pickup the CM1000
