sir_percival
May 19, 2018Tutor
RBS40 solid blue light stays on permanently
Has anyone found the fix to the solid blue light that stays on?
My RBS40 satellite has this problem ever since I bought it.
Can tech support put in a fix to disable the light so I can place it in...
sir_percival
May 21, 2018Tutor
Unfortunately, after following the steps outlined, My satellite still is showing solid blue.
- budyMay 21, 2018Luminary
You issued ledcontrol on the satellite and the LED went out… and it then came online again? Did the satellite restart - or the router for that matter? As I said, the LED ring would only light up again, of triggered by the Orbi OS.
- sir_percivalMay 21, 2018Tutor
I issued the command but the blue light from the sattelite did not change, it remained solid blue. Both the satelite or the router did not restart. For what its worth, I was able to login via telnet and copied and pasted your command and did not receive any confirmation returned.
yeah - there is actually no output from ledcontrol… NG seems to think, that it's unlikely - even close to improbable, that ony human will ever issue this command manually, so why bother with some output?
Anyway, if the LED ring stays on, then there's maybe something wrong with your satellite. In this case, I'd actually suggest to power-cycle it and see, if this goes away.
