sir_percival
May 20, 2018Tutor
RBS40 solid blue light stays on permanently
Has anyone found the fix to the solid blue light that stays on?
My RBS40 satellite has this problem ever since I bought it.
Can tech support put in a fix to disable the light so I can place it in...
sir_percival
Oct 09, 2018Tutor
Unfortunately, after an hour and a half with tech support of them troubleshooting some of the steps I already did, they reluctantly sent me a replacement unit under warranty. This new unit has worked without a hitch. I recommmend you contact tech support if the steps outlined here does not work instead of in my case wasting hours on end trying to figure it out as it was definitely a hardware issue in my case.
Oct 09, 2018Guru - Experienced User
Thanks for posting and letting us know. Glad the new unit works. Seems like a HW failure for sure. Enjoy. :smileywink:
