sir_percival
May 20, 2018Tutor
RBS40 solid blue light stays on permanently
Has anyone found the fix to the solid blue light that stays on?
My RBS40 satellite has this problem ever since I bought it.
Can tech support put in a fix to disable the light so I can place it in...
LWGma2016
Oct 09, 2018Aspirant
How do I power cycle the satellite (to get the blue light to turn off)???
Oct 09, 2018Guru - Experienced User
Your unit might be to be replaced as per sir_percival
