tonydigimon
Sep 30, 2020Aspirant
RBS40 very weak 5g wifi
I just bought the rbk 40. The router is working fine yet i got very weak signal on satellite for 5g wifi. Meanwhile the 2.4g wifi is working fine. I am using the wired backhaul. I am not sure if...
Sep 30, 2020Guru - Experienced User
Is the RBS directly connected to the back of the RBR or is there a switch in between?
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Are you next to the RBS when looking at the signal or at a distance?
What does the RBRs connected clients web page show for connection status?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
- tonydigimonSep 30, 2020Aspirant
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?V2.5.1.22
I don't think the modem is related as the router is working fine.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...It is directly connect. I have a desktop connecting to the satellite via wire and it is working fine as well. The only issue is the weak 5G wifi
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerMy home is only 400sq ft, yet there is a wall between my room and router so I have put a satallite in my room. Otherwise I can only get a very weak wifi signal from the router.
Yes I am next to the RBS.
In RBR it is showing fine with all devices connnected to satellite using 2.4G only.
