tonydigimon
Sep 30, 2020Aspirant
RBS40 very weak 5g wifi
I just bought the rbk 40. The router is working fine yet i got very weak signal on satellite for 5g wifi. Meanwhile the 2.4g wifi is working fine. I am using the wired backhaul. I am not sure if...
Mstrbig
Oct 01, 2020Master
I am not sure if it is due to some hardware issue . any setting i should change to get better 5g signal from the satellite?
Try these settings:
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence.
Enable WMM, Implicit BeamForming, Mu-MIMO
Set Short preamble mode. Save settings, reboot Orbi.
If wired, what cable size was used, as wrong size can cause slow speed.
- tonydigimonOct 01, 2020Aspirant
Tried using the settting remmended. Still got no luck on the 5G wifi. I could only receive a signal with -79dbm even if I am sitting next to the router.
I wonder if anything I could use to test the satellite 5G signal alone.. otherwise I may need to go for warranty
- FURRYe38Oct 01, 2020Guru - Experienced User
Your modem doesn't have wifi does it? Reason for asking about this earlier.
I recommend contact NG support and ask them for help on this. You may need an RMA on the RBS.
- tonydigimonOct 01, 2020AspirantThanks
My modem does not have wifi
Probably i shouls go to RMA then
