tonydigimon
Sep 30, 2020Aspirant
RBS40 very weak 5g wifi
I just bought the rbk 40. The router is working fine yet i got very weak signal on satellite for 5g wifi. Meanwhile the 2.4g wifi is working fine. I am using the wired backhaul. I am not sure if...
tonydigimon
Oct 01, 2020Aspirant
Tried using the settting remmended. Still got no luck on the 5G wifi. I could only receive a signal with -79dbm even if I am sitting next to the router.
I wonder if anything I could use to test the satellite 5G signal alone.. otherwise I may need to go for warranty
Oct 01, 2020Guru - Experienced User
Your modem doesn't have wifi does it? Reason for asking about this earlier.
I recommend contact NG support and ask them for help on this. You may need an RMA on the RBS.
- tonydigimonOct 01, 2020AspirantThanks
My modem does not have wifi
Probably i shouls go to RMA then
