DaleHuff
Apr 07, 2019Aspirant
RBS40 wont connect to the RBR40
I've had this for about 6 mnths and as far as I know it's been working fine. Then about a week ago the satellite stopped being connected to the router. I have WIFI, but no where can I find the satell...
Apr 07, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
How is the RBS connected? Wired or wireless?
Try a factory reset on the RBS and then try to re-add it. If it appears in the RBR web page, see if you can remove it first, then re-add. Do this while in same room as the RBR...
A factory reset maybe needed on the RBR as well...
DaleHuff wrote:
I've had this for about 6 mnths and as far as I know it's been working fine. Then about a week ago the satellite stopped being connected to the router. I have WIFI, but no where can I find the satellite. Not on the app or when I look on the Netgear website.
All the satellite will do is continually flash the white light 10 times then it will very briefly flash a green light then briefly an orange light sometimes another orange one after that then it repeats the process.
I'm not at all literat with this kind of thing so any help that could be simplified for me to undestand would be of great help.
- DaleHuffApr 07, 2019Aspirant
FW....V2.3.1.44
Modem...Netgear, CM700
Connected with wire
Operating in Router.
WIFI neighbors...not really sure about this but it looks like 6. 5 are devices in my home ie, TV. One is a house next door, one one is marked to connect automatically that's the Orbi.
Tried a factory reset earlyer, pushing button seemed to do no good. What I mean is that there wasn't any type of response at all.
I hope this helpfull to you, thank you for trying.
- FURRYe38Apr 08, 2019Guru - Experienced User
Are you pushing the reset button on the RBS to where you feel a bump in the press? Hold the reset button in until the top led turns AMBER or starts to blink WHITE, then let go of the button.
- MistermccheeseApr 22, 2019Aspirant
i have the same model and same problem satalite isnt responding to anything and is not discoverable
