DaleHuff
Apr 07, 2019Aspirant
RBS40 wont connect to the RBR40
I've had this for about 6 mnths and as far as I know it's been working fine. Then about a week ago the satellite stopped being connected to the router. I have WIFI, but no where can I find the satell...
DaleHuff
FW....V2.3.1.44
Modem...Netgear, CM700
Connected with wire
Operating in Router.
WIFI neighbors...not really sure about this but it looks like 6. 5 are devices in my home ie, TV. One is a house next door, one one is marked to connect automatically that's the Orbi.
Tried a factory reset earlyer, pushing button seemed to do no good. What I mean is that there wasn't any type of response at all.
I hope this helpfull to you, thank you for trying.
Apr 08, 2019Guru - Experienced User
Are you pushing the reset button on the RBS to where you feel a bump in the press? Hold the reset button in until the top led turns AMBER or starts to blink WHITE, then let go of the button.
- MistermccheeseApr 22, 2019Aspirant
i have the same model and same problem satalite isnt responding to anything and is not discoverable
- FURRYe38Apr 22, 2019Guru - Experienced User
Has the FW been updated on the RBR and RBS at all?
Connect a wired PC to the back of the RBS and power it on. Wait up to 5 minutes, the PC should get an IP address. Open a web browser and try to access the RBS web page at 192.168.1.254. Can apply any FW updates at this point if needed.
- MistermccheeseApr 24, 2019Aspirant
router fw V2.3.1.48
no idea about satalie because i cant find anywhere and connecting to that ip wont work says connection interupted
