awchapman
May 09, 2021Aspirant
RBS40V - lost connection to system
I have a RBR40 system with 3 satellites on different levels of a 3 story home. We added an RBS40V to the original system (all purchased together). It worked great for several months but now I canno...
CrimpOn
May 09, 2021Guru - Experienced User
What does the Orbi Attached Devices display show for the RBS40V?
One step would be to use the Attached devices display to remove the RBS40V, do a Factory Reset on the RBS40V, and then attempt to "add a satellite" with it. (I am most comfortable adding satellites when they are physically in the same room as the router. Makes it much easier to 'see' what is going on and to press the sync buttons within the time frame.)
awchapman
it doesn't show anything connected to it and it shows it as offline
- CrimpOnMay 09, 2021Guru - Experienced User
awchapman wrote:it doesn't show anything connected to it and it shows it as offline
In my previous life in tech support, when I would ask the user, "is it plugged in?", they would often berate me, then crawl under the desk and say, "well, it is now." Assuming that the RBS40V is plugged in and the Power LED glows green, the most obvious step is a factory reset and then sync it to the router again.
- awchapmanMay 11, 2021Aspirant
That is the first thing I check as well. I have even moved it to different outlets within the room to be sure the outlet isn't bad.
What are the steps for a factory reset?
- FURRYe38May 11, 2021Guru - Experienced User
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
awchapman wrote:That is the first thing I check as well. I have even moved it to different outlets within the room to be sure the outlet isn't bad.
