suri_164
Sep 16, 2020Aspirant
RBS40V-200 as Extension for RBR50
I need to get another satellite for my RBR50 AC3000 Router. Is NETGEAR Orbi Voice Smart Speaker and WiFi Mesh Extender with Amazon Alexa Built-in (RBS40V-200) compatible to use as Extension for RBR50...
- Sep 16, 2020
yes. It works great.
Just keep in mind though the 50 series has a 1733mbps and the 40 series the 866mbps backhaul.
You shoudn't notice much difference though.
Sep 16, 2020Guru - Experienced User
Mstrbig
Sep 16, 2020Master
And it's on sale right now for $99.00. It sounds great as well as has great coverage.
