suri_164's avatar
suri_164
RBS40V-200 as Extension for RBR50
I need to get another satellite for my RBR50 AC3000 Router. Is NETGEAR Orbi Voice Smart Speaker and WiFi Mesh Extender with Amazon Alexa Built-in (RBS40V-200) compatible to use as Extension for RBR50...
  • plemans's avatar
    Sep 16, 2020
    yes. It works great.
    Just keep in mind though the 50 series has a 1733mbps and the 40 series the 866mbps backhaul.
    You shoudn't notice much difference though.
