advidesilvaNZ
Sep 13, 2020Follower
RBS40v Adapter for NZ
Hi Everyone, I was hoping for some assistance with choosing a new power adapter for the RBS40V. I live in NZ and the adapter I had just packed up. Is there anywhere I can go for spare parts for t...
Tansan
Nov 04, 2020Aspirant
Hi, did you manage to find a solution to finding a replacement orbi voice power adapter for NZ? I live in NZ and just bought my Orbi voice online from USA and have found that the voltage on the adapter is 120v input and not 240v which is NZ voltage rate. So the orbi voice power adapter is only suitable to be used in the USA. I am wondering if I should buy a step down transformer to plug the 120v power adapter into it to make it compatible with NZ 240v ac current or if another solution or power adapter can be found to use as a replacement for the Orbi Voice power adapter? Did the PBtech or Jaycar adapters work for you?
michaelkenward
Nov 04, 2020Guru - Experienced User
Many people, including me, have found that the adapters labelled 120 V are really multivoltage. They will happily work on 240 V without going bang. I have various Netgear devices doing just that.
Try the adapter with nothing connected to it. If it survives the shock, then you should be safe. If it does blow up then you have only killed a useless transformer
- TansanNov 04, 2020Aspirant
Hi, I tried plugging it in no problems. Then I found it worked for a while while I was setting it up then it stopped working and I found the transformer was hot and was dripping a clear substance on the transformer unit when pulling it out of the wall outlet. I let it cool down and replugged into another wall outlet hours later and found that power is not being transferred to the orbi voice at all as I can't turn the orbi voice unit on. So no step down currency converter will work for me as the transformer is not working. Hopefully the orbi voice is not damaged and it is just the transformer that is defective. I suppose the only option for me is to go to an electronic supplies shop and see if I can find an another ac transformer adapter and plug with the correct output voltage to replace the original orbi ac transformer. Does anyone know if netgear produce a AC240v compatible transformer for this unit? I assumed that since the orbi RBS50 units I bought online from the USA have transformers with multi voltage worldwide support and worked for me in NZ that the Orbi voice would offer a similar multi voltage transformer.
