whenasked
Mar 10, 2021Aspirant
RBS40V and 2.4Ghz
I have a RBR50, RBS50 on Router Firmware Version V2.7.2.104. I also have RBS40V on Firmware Version: V2.6.2.4_1.0.1. When devices connect to 2.4Ghz on RBS40V, devices stop working. When I switc...
whenasked
In orbi mode. Tried several resets..same result
plemans wrote:do you have the voice running in extender mode or orbi mode?
also, have you tried a simple factory reset and reinstall of the voice?
Mar 10, 2021Guru - Experienced User
If you log into the rbs40V using its ip address, what does it show for its status page?
