JPBOLDY
Jun 29, 2021Star
RBS40v and RBR50 WiFi speed issues
For sometime now I have seen bad WiFi speeds on my orbi system which main router is a RBR50 and a RBS40V satalite. The satalite is roughly 12 metre's away from the RBR50 with only 1 ceiling obstruc...
Jul 01, 2021Guru - Experienced User
Is the RBS40v wirelessly connected to the RBR?
Disable the EAX20 and see if this changes anything. Possible the RBS40v is connecting to the EAX20 or EAX20 is causing some interferences.
JPBOLDY
Jul 01, 2021Star
No I don't think the rbs40v is connecting to the EAX20 as with it been a mesh system the rbs40v is connected to the rbr50 also in the rbr50 settings it's clearly shows the rbs40v is connected via backhual and connection is good.
I will try and turn off the EAX20 to see if this is causing interference
- FURRYe38Jul 01, 2021Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?- JPBOLDYJul 01, 2021StarHi
2.4ghz is on 6
5ghz is on 36
Neighbouring networks are on 1 and 12 - JPBOLDYJul 01, 2021StarAlso in that link of suggested things to enable and disable I've tried that and didn't change anything in some cases made issues worse.
Ok. Thanks for letting us know.
What FW versions are loaded on the RBR50 and RBS40v?
