JPBOLDY
Jun 29, 2021Star
RBS40v and RBR50 WiFi speed issues
For sometime now I have seen bad WiFi speeds on my orbi system which main router is a RBR50 and a RBS40V satalite. The satalite is roughly 12 metre's away from the RBR50 with only 1 ceiling obstruc...
JPBOLDY
Jul 01, 2021Star
No I don't think the rbs40v is connecting to the EAX20 as with it been a mesh system the rbs40v is connected to the rbr50 also in the rbr50 settings it's clearly shows the rbs40v is connected via backhual and connection is good.
I will try and turn off the EAX20 to see if this is causing interference
Jul 01, 2021Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- JPBOLDYJul 01, 2021StarHi
2.4ghz is on 6
5ghz is on 36
Neighbouring networks are on 1 and 12 - JPBOLDYJul 01, 2021StarAlso in that link of suggested things to enable and disable I've tried that and didn't change anything in some cases made issues worse.
- FURRYe38Jul 01, 2021Guru - Experienced User
Ok. Thanks for letting us know.
What FW versions are loaded on the RBR50 and RBS40v?
- JPBOLDYJul 01, 2021StarRBR50 is V2.7.2.104
RBS40V is V2.6.2.4_1.0.1
After the firmware was installed a while ago I also did a full reset on both satalite and router using the pin hole on both and setup the system from scratch.
