sandy641
Dec 04, 2020Tutor
RBS40V doesn't connecte to Ring Doorbell
My RBS40V does not connect to my RING doorbell. My Amazon Echo does and it chimes when the doorbell is pressed. How do I pair the RING doorbell to the RBS40V ?
CrimpOn
Dec 04, 2020Guru - Experienced User
sandy641 wrote:My RBS40V does not connect to my RING doorbell.
Can you please expand on the situation? i.e.
- the Ring doorball is connected to the Orbi WiFi network.
- When someone presses the button, the Ring app gets notified
- When someone presses the button, the Echo chimes
- The question is how to make the RBS40V chime when the doorbell is pressed?
Is this the situation?
sandy641
Dec 07, 2020Tutor
Yes, how can we pair the RING doorbell to the ORBI voice (RBS40V)? My router is a RBR40.
I do believe the RING doorbell is connected to the ORBI network since my echo chimes when the doorbell is pressed.
I am a novice so please answer with detail.
Many thanks for your assistance.
- CrimpOnDec 07, 2020Guru - Experienced User
sandy641 wrote:Yes, how can we pair the RING doorbell to the ORBI voice (RBS40V)? My router is a RBR40.
So far, my Orbi voice does play music ("Alexa, play KUSC radio") I fear that Netgear may not have implemented as many Alexa skills as customers want. For example, this person is NOT happy:
There is a community forum specifically for the voice model here: https://community.netgear.com/t5/Orbi-Voice-WiFi-Meets-HiFI/bd-p/en-home-orbi-voice
