pachy's avatar
pachy
Tutor
Sep 21, 2023
RBS40V Firmware update
Trying a manual update. The website contains firmware files but they are all .chk. The update requires an .img file. Where do I find the proper file? Thanks,
  • CrimpOn's avatar
    CrimpOn
    Sep 21, 2023
    The upper part of the manual update page (above the line) is for the router, which requires an *.img file.
    Click on Update below the line to update the satellite.
    (I personally prefer to log into the satellite web page directly using its IP address and select Update Firmware from the satellite home page.)
