pachy
Sep 21, 2023Tutor
RBS40V Firmware update
Trying a manual update. The website contains firmware files but they are all .chk. The update requires an .img file. Where do I find the proper file? Thanks,
- Sep 21, 2023
The upper part of the manual update page (above the line) is for the router, which requires an *.img file.
Click on Update below the line to update the satellite.
(I personally prefer to log into the satellite web page directly using its IP address and select Update Firmware from the satellite home page.)
Sep 21, 2023Guru - Experienced User
The RBS web page should be accepting the .chk file.
What browser are you using?
pachy
Sep 21, 2023Tutor
Mac Book Pro Ventura 13.5.2
Safari 16.6
I can login to the orbi stuff ok. I have several orbi products, all are up to date except the RBS40V which is at 2.3.6.4
I have downloaded from the Netgear web site each of the subsequent firmware.
ALL of them are .chk files.
When I Browse to locate them, it accepts them as "found" but when I click on Upload I get the message that it has to be an .img file.
I've attached 2 screen grabs. Thanks.
- CrimpOnSep 21, 2023Guru - Experienced User
- pachySep 21, 2023Tutor
Many thanks. I went directly to the RBS40V - and after remembering the password - was able to update. I took it carefully, step by step but am now at v 2.6.2.8.
Many thanks.
- FURRYe38Sep 21, 2023Guru - Experienced User
Does this happen on the RBS web page and not the RBRs web page?
Safari 16.6
