arthur-m
Aug 09, 2020Tutor
RBS40V firmware V2.5.1.6
Using orbilogin.com to check on firmware updates for my RBR50, RBS50 & RBS40V, I see that there is a firmware update to the Orbi Voice, to V2.5.1.6, from V2.5.1.2. My other two devices are at V2.5.1....
Aug 10, 2020Guru - Experienced User
I did the update and haven't had any issues. here's the release notes:
Bug Fixes:
- The RBS40V sometimes broadcasted a non-secured SSID when connecting to the Orbi network.
- The device link rate sometimes displayed incorrectly for devices connected to the RBS40V.
- KKBOX could not be displayed in the Orbi app in the Macau area.
- Fixes some security issues.
Mstrbig
Aug 12, 2020Master
Updated when installed, works perfectly with no issues.
