Bodack
Jan 18, 2022Guide
RBS40v Keeps disconnecting Alexa?
Hey all, My Orbi voice keeps randomly disconnecting from alexa in general. As I reset up it works for a little bit but then a day later it randomly says to check alexa / orbi app settings. For what...
CrimpOn
Jan 18, 2022Guru - Experienced User
Does it 'speak' this message, or does it appear on the app?
Bodack
Jan 18, 2022Guide
It will specifically speak this message indefinitely after a few days after resetting it. Like example I reset via the app now and it listens to me, but probably 3 days from now will start doing it again which is annoying. Is there a previous firmware that runs better that I should downgrade to maybe?
- CrimpOnJan 18, 2022Guru - Experienced UserBeats me. Do not recall ever hearing a message like that. Hope another Orbi voice owner sees your post.
