Bodack
Jan 18, 2022Guide
RBS40v Keeps disconnecting Alexa?
Hey all, My Orbi voice keeps randomly disconnecting from alexa in general. As I reset up it works for a little bit but then a day later it randomly says to check alexa / orbi app settings. For what...
Bodack
Apr 30, 2022Guide
The message is as is:
"Sorry. I'm having trouble understanding right now. For help go to the Netgear Orbi App."
It repeatedly goes from working and not working. The app doesn't give any help options either.
- DanInGAOct 28, 2022Tutor
Same exact problem here for months, same model, RBS40v. I can reset it in the Alexa app and it works for a bit, but it happens again sometimes within 30 min to 1 hr.. I have searched all over the internet and have found no solution as of yet.
I did find this one article, but tried it and the problem continues. Hope it works for you:
- BodackOct 28, 2022GuideHonestly never found a solution and netgear kept sending tech support calls when I was at work. Barely could work with on my schedule. I have a paperweight I guess
- SfuriyaNov 28, 2022AspirantDid you ever find a solution? I get this all the time. When I can be bothered I reinstall Alexa and then she works for a few minutes and then it’s back to “I’m sorry - I’m having a hard time understanding right now” and then I give up.
The satellite is working fine just not the Voice part.- culpeperleftyJan 28, 2023Aspirant
Same exact problem wondering if any solutions. If I turn off the Orbi Voice Alexa works for a short time but then defaults to "Sorry I'm having a hard time understanding right now. For help go to the Orbi app"
- CrimpOnJan 28, 2023Guru - Experienced User
Is this a typing error? ("off")
