Bodack
Jan 18, 2022Guide
RBS40v Keeps disconnecting Alexa?
Hey all, My Orbi voice keeps randomly disconnecting from alexa in general. As I reset up it works for a little bit but then a day later it randomly says to check alexa / orbi app settings. For what...
MarkRamos
May 13, 2022Aspirant
I currently have an Alexa Echo speaker right in the middle of the house, on the first floor in a center location. I have also have a wired Gigabit ethernet connection available in this central location.
I wanted to potentially disable the Wifi on the router, but still keep it as a router, and install an RBS40V in the center location using wired backhaul to the router(essentially as an access point).
