Bodack
Jan 18, 2022Guide
RBS40v Keeps disconnecting Alexa?
Hey all, My Orbi voice keeps randomly disconnecting from alexa in general. As I reset up it works for a little bit but then a day later it randomly says to check alexa / orbi app settings. For what...
Bodack
Apr 30, 2022Guide
The message is as is:
"Sorry. I'm having trouble understanding right now. For help go to the Netgear Orbi App."
It repeatedly goes from working and not working. The app doesn't give any help options either.
DanInGA
Oct 28, 2022Tutor
Same exact problem here for months, same model, RBS40v. I can reset it in the Alexa app and it works for a bit, but it happens again sometimes within 30 min to 1 hr.. I have searched all over the internet and have found no solution as of yet.
I did find this one article, but tried it and the problem continues. Hope it works for you:
- BodackOct 28, 2022GuideHonestly never found a solution and netgear kept sending tech support calls when I was at work. Barely could work with on my schedule. I have a paperweight I guess
