Bodack
Jan 18, 2022Guide
RBS40v Keeps disconnecting Alexa?
Hey all, My Orbi voice keeps randomly disconnecting from alexa in general. As I reset up it works for a little bit but then a day later it randomly says to check alexa / orbi app settings. For what...
DanInGA
Oct 28, 2022Tutor
Same exact problem here for months, same model, RBS40v. I can reset it in the Alexa app and it works for a bit, but it happens again sometimes within 30 min to 1 hr.. I have searched all over the internet and have found no solution as of yet.
I did find this one article, but tried it and the problem continues. Hope it works for you:
Bodack
Oct 28, 2022Guide
Honestly never found a solution and netgear kept sending tech support calls when I was at work. Barely could work with on my schedule. I have a paperweight I guess
