Bodack
Jan 18, 2022Guide
RBS40v Keeps disconnecting Alexa?
Hey all, My Orbi voice keeps randomly disconnecting from alexa in general. As I reset up it works for a little bit but then a day later it randomly says to check alexa / orbi app settings. For what...
Bodack
Apr 30, 2022Guide
The message is as is:
"Sorry. I'm having trouble understanding right now. For help go to the Netgear Orbi App."
It repeatedly goes from working and not working. The app doesn't give any help options either.
Sfuriya
Nov 28, 2022Aspirant
Did you ever find a solution? I get this all the time. When I can be bothered I reinstall Alexa and then she works for a few minutes and then it’s back to “I’m sorry - I’m having a hard time understanding right now” and then I give up.
The satellite is working fine just not the Voice part.
- culpeperleftyJan 28, 2023Aspirant
Same exact problem wondering if any solutions. If I turn off the Orbi Voice Alexa works for a short time but then defaults to "Sorry I'm having a hard time understanding right now. For help go to the Orbi app"
- CrimpOnJan 28, 2023Guru - Experienced User
Is this a typing error? ("off")
- BodackJan 28, 2023GuideI never had a solution and netgear repeatedly picked inconvenient times for me to troubleshoot to help fix. I wonder if they would ever offer me a device that just.. worked.
He is right thought power on and off the device it might work for an hour then it resumes to not know anything
